SPBM Configuration Examples
This section provides configuration examples to configure basic SPBM and IS-IS infrastructure.
Examples and network illustrations in this document may not include your specific platform. Unless otherwise noted, the concept illustrated applies to all supported platforms. For information about high-level feature support, see Fabric Engine and VOSS Feature Matrix.
The following figure shows a sample greenfield deployment for SPBM.
For migration purposes, SPBM can coexist with existing SMLT configurations.
The following sections show the steps required to configure the Ethernet and MLT interfaces in this example.
SwitchC
PORT CONFIGURATION - PHASE 1 interface GigabitEthernet 1/30 encapsulation dot1q exit
SwitchG
PORT CONFIGURATION - PHASE 1 interface GigabitEthernet 1/5 encapsulation dot1q exit MLT CONFIGURATION mlt 1 enable mlt 1 member 1/21-1/22 mlt 1 encapsulation dot1q
SwitchD
MLT CONFIGURATION mlt 1 enable mlt 1 member 1/20,1/30 mlt 1 encapsulation dot1q
The following figure shows the IS-IS area information added to the network.
The following sections show the steps required to configure the global IS-IS SPBM parameters in this example.
SwitchC
enable configure terminal prompt SwitchC BOOT CONFIGURATION spbm spbm ethertype 0x8100 ISIS SPBM CONFIGURATION router isis spbm 1 spbm 1 nick-name f.30.13 spbm 1 b-vid 20 ISIS CONFIGURATION is-type l1 manual-area 30.0000 sys-name SwitchC exit router isis enable VLAN CONFIGURATION vlan create 20 name "B-VLAN" type spbm-bvlan
SwitchG
enable configure terminal prompt SwitchG BOOT CONFIGURATION spbm spbm ethertype 0x8100 ISIS SPBM CONFIGURATION router isis spbm 1 spbm 1 nick-name f.30.10 spbm 1 b-vid 20 ISIS CONFIGURATION is-type l1 manual-area 30.0000 sys-name SwitchG exit router isis enable VLAN CONFIGURATION vlan create 20 name "B-VLAN" type spbm-bvlan
SwitchD
enable configure terminal prompt SwitchD BOOT CONFIGURATION spbm spbm ethertype 0x8100 ISIS SPBM CONFIGURATION router isis spbm 1 spbm 1 nick-name f.30.14 spbm 1 b-vid 20 ISIS CONFIGURATION is-type l1 manual-area 30.0000 sys-name SwitchD exit router isis enable VLAN CONFIGURATION vlan create 20 name "B-VLAN" type spbm-bvlan
The following figure shows the IS-IS area information and interfaces in the network.
The following sections show the steps required to configure the IS-IS SPBM interfaces in this example.
SwitchC
PORT CONFIGURATION - PHASE II interface GigabitEthernet 1/30 isis isis spbm 1 isis enable exit
SwitchG
PORT CONFIGURATION - PHASE II interface GigabitEthernet 1/5 isis isis spbm 1 isis enable exit MLT INTERFACE CONFIGURATION interface mlt 1 isis isis spbm 1 isis enable exit
SwitchD
The following sections show the output from verifying the sample IS-IS SPBM configuration.
Checking Operation — SwitchC
SwitchC:1# show isis interface =================================================================================================================== ISIS Interfaces =================================================================================================================== IFIDX TYPE LEVEL OP-STATE ADM-STATE ADJ UP-ADJ SPBM-L1 OP-SPBM- ORIGIN AREA AREA-NAME -METRIC L1-METRIC -------------------------------------------------------------------------------------------------------------------- Port1/30 pt-pt Level 1 UP UP 1 1 10 (A) 10 CONFIG HOME area-9.00.02 -------------------------------------------------------------------------------------------------------------------- Home: 1 out of 1 Total Num of ISIS Interfaces -------------------------------------------------------------------------------------------------------------------- Legend: (A): l1 metric is automatically updated based on detected interface speed.
SwitchC:1# show isis adjacencies ==================================================================================================== ISIS Adjacencies ==================================================================================================== INTERFACE L STATE UPTIME PRI HOLDTIME SYSID HOST-NAME STATUS AREA AREA-NAME ---------------------------------------------------------------------------------------------------- Port1/30 1 UP 1d 19:19:52 22 beb0.0000.7204 SwitchC ACTIVE HOME area-9.00.02 ---------------------------------------------------------------------------------------------------- Home: 1 out of 1 interfaces have formed an adjacency Remote: 0 out of 0 interfaces have formed an adjacency ----------------------------------------------------------------------------------------------------
SwitchC:1# show isis spbm unicast-fib ================================================================================================== SPBM UNICAST FIB ENTRY INFO ================================================================================================== DESTINATION BVLAN SYSID HOST-NAME OUTGOING COST AREA AREA-NAME ADDRESS INTERFACE -------------------------------------------------------------------------------------------------- 00:0e:62:25:a3:df 4000 0016.ca23.73df SwitchG 1/30 10 HOME area-9.00.02 00:14:0d:a0:13:df 4000 0014.0da0.13df SwitchD 1/30 10 HOME area-9.00.02 -------------------------------------------------------------------------------------------------- Home: Total number of SPBM UNICAST FIB entries 2 Remote: Total number of SPBM UNICAST FIB entries 0 -------------------------------------------------------------------------------------------------- SwitchC:1# show isis spbm unicast-tree 4000 Node:000e.6225.a3df.00 (SwitchG) -> ROOT Node:0014.0da0.13df.00 (SwitchD) -> Node:000e.6225.a3df.00 (SwitchG) -> ROOT
Checking Operation — SwitchG
SwitchG:1# show isis interface =================================================================================================================== ISIS Interfaces =================================================================================================================== IFIDX TYPE LEVEL OP-STATE ADM-STATE ADJ UP-ADJ SPBM-L1 OP-SPBM- ORIGIN AREA AREA-NAME -METRIC L1-METRIC -------------------------------------------------------------------------------------------------------------------- Port1/5 pt-pt Level 1 UP UP 1 1 10 (A) 10 CONFIG HOME area-9.00.02 Mlt1 pt-pt Level 1 UP UP 1 1 10 (A) 10 CONFIG HOME area-9.00.02 -------------------------------------------------------------------------------------------------------------------- Home: 2 out of 2 Total Num of ISIS Interfaces -------------------------------------------------------------------------------------------------------------------- Legend: (A): l1 metric is automatically updated based on detected interface speed.
SwitchG:1# show isis adjacencies ==================================================================================================== ISIS Adjacencies ========================================================================================================= INTERFACE L STATE UPTIME PRI HOLDTIME SYSID HOST-NAME STATUS AREA AREA-NAME --------------------------------------------------------------------------------------------------------- Port1/30 1 UP 1d 19:19:52 127 26 beb0.0000.7204 SwitchC ACTIVE HOME area-9.00.02 Mlt1 1 UP 04:57:34 127 20 0014.0da0.13df SwitchD ACTIVE HOME area-9.00.02 --------------------------------------------------------------------------------------------------------- Home: 2 out of 2 interfaces have formed an adjacency Remote: 0 out of 0 interfaces have formed an adjacency ----------------------------------------------------------------------------------------------------
SwitchG:1# show isis spbm unicast-fib ================================================================================================== SPBM UNICAST FIB ENTRY INFO ================================================================================================== DESTINATION BVLAN SYSID HOST-NAME OUTGOING COST AREA AREA-NAME ADDRESS INTERFACE -------------------------------------------------------------------------------------------------- 00:14:0d:a0:13:df 4000 0014.0da0.13df SwitchD MLT-1 10 HOME area-9.00.02 00:15:e8:9f:e3:df 4000 0015.e89f.e3df SwitchC 1/5 10 HOME area-9.00.02 -------------------------------------------------------------------------------------------------- Home: Total number of SPBM UNICAST FIB entries 2 Remote: Total number of SPBM UNICAST FIB entries 0 -------------------------------------------------------------------------------------------------- SwitchG:1# show isis spbm unicast-tree 4000 Node:0015.e89f.e3df.00 (SwitchC) -> ROOT Node:0014.0da0.13df.00 (SwitchD) -> ROOT
Checking Operation — SwitchD
SwitchD:1# show isis interface =================================================================================================================== ISIS Interfaces =================================================================================================================== IFIDX TYPE LEVEL OP-STATE ADM-STATE ADJ UP-ADJ SPBM-L1 OP-SPBM- ORIGIN AREA AREA-NAME -METRIC L1-METRIC -------------------------------------------------------------------------------------------------------------------- Mlt1 pt-pt Level 1 UP UP 1 1 10 (A) 10 CONFIG HOME area-9.00.02 -------------------------------------------------------------------------------------------------------------------- Home: 1 out of 1 Total Num of ISIS Interfaces -------------------------------------------------------------------------------------------------------------------- Legend: (A): l1 metric is automatically updated based on detected interface speed.
SwitchD:1# show isis adjacencies ===================================================================================================== ISIS Adjacencies ===================================================================================================== INTERFACE L STATE UPTIME PRI HOLDTIME SYSID HOST-NAME STATUS AREA AREA-NAME ----------------------------------------------------------------------------------------------------- Mlt1 1 UP 05:03:59 127 21 000e.6225.a3df SwitchG ACTIVE HOME area-9.00.02 ----------------------------------------------------------------------------------------------------- Home: 1 out of 1 interfaces have formed an adjacency Remote: 0 out of 0 interfaces have formed an adjacency -----------------------------------------------------------------------------------------------------
SwitchD:1# show isis spbm unicast-fib ================================================================================================== SPBM UNICAST FIB ENTRY INFO ================================================================================================== DESTINATION BVLAN SYSID HOST-NAME OUTGOING COST AREA AREA-NAME ADDRESS INTERFACE -------------------------------------------------------------------------------------------------- 00:0e:62:25:a3:df 4000 000e.6225.a3df SwitchG MLT-1 10 HOME area-9.00.02 00:15:e8:9f:e3:df 4000 0015.e89f.e3df SwitchC MLT-1 10 HOME area-9.00.02 -------------------------------------------------------------------------------------------------- Home: Total number of SPBM UNICAST FIB entries 2 Remote: Total number of SPBM UNICAST FIB entries 0 -------------------------------------------------------------------------------------------------- SwitchD:1# show isis spbm unicast-tree 4000 Node:000e.6225.a3df.00 (SwitchG) -> ROOT Node:0015.e89f.e3df.00 (SwitchC) -> Node:000e.6225.a3df.00 (SwitchG) -> ROOT
